Pārdod auto audio jaudas pastiprinātāju
05 Jan 2015, 00:46
Tiek tirgots pastiprinātājās, vajadzētu būt darba kārtībā, nopirktu pirms 5 gadi, tā arī skapī nostāvēja un auto neieliku, testējis neesmu, ja nedarbosies nauda protams tiks atdota :draugi: Cena 30 euro
Specifikāciju atradu internetā
WANDEL V12 4/3/2 Channel Power Amplifier 1000Watts
Average Power Output/CH into 4 Ohms, 4 Channels Driven @10Hz~40kHz, 0.5% THD 85W X 4 or 170W X 2Ch @1kHz, 10% THD 250W X 4Ch or 500W X 2Ch (Total Harmonic Distortion (THD) Amount of change in harmonic content of the signal as it is amplified. A lower figure indicates less change and a more accurate amp. THD below 1% is inaudible.)
Low Pass Filter (VARIABLE) 40Hz ~ 150kHz
High Pass Filter (VARIABLE) 80Hz ~ 1.2kHz
Output of Bridged (BTL) Operation into 4 Ohms @ 1kHz, 1% THD 1000Watts
Frequency Response (-1dB) 10Hz ~ 40kHz
Signal to Noise Ratio ("A" WTD) >100dB
Input Sensitivity 100mV ~3V
Input Impedance 22k Ohms
Operation Voltage (Negative Ground) DC 12V
Speaker Impedance @ Stereo Driven 4 Ohms
Fuse Rating 40A X 1
Dimension (WxHxD)mm 260X58X320 Weight 3.2KG
Re: Pārdod auto audio jaudas pastiprinātāju
05 Jan 2015, 01:22
Rezervēts :!:
Users browsing this forum: Semrush [Bot] and 7 guests
