olivier
Re: French Jigouli
02 Jun 2015, 13:52
Hi, i checked yesterday and changed position 1 for position 4.... without any result.
Maybe the problem could come from ignition : condeser, breaker, distributor cap,distributor rotors .....
Re: French Jigouli
02 Jun 2015, 16:22
When you changed timing chain did you do everything according to the book by matching the point marked on camshaft gear or just took the gear off changed chain and put it back together?
I have changed chain, but there shouldn't be a problem with ignition if you do it all according to procedure :problem:
olivier
Re: French Jigouli
05 Jun 2015, 13:23
Wipers, i think the problem come from timing belt yest!
When i changed it i did fast and i blocked just the crank shaft, the camshaft gear moved for half a tour.
I noticed it when i finished installed the new timing belt. it was impossible to rotate the engine... :(
so i uninstalled everything, moved the camshaft gear till the good brand. And once everything installed, i could make 2 rounds of engine perfectly.
Maybe the marks moved and i should verify everything again...
Users browsing this forum: No registered users and 9 guests
